Tibout Posted January 19, 2011 Share Posted January 19, 2011 hi guys so landy is a disco 300tdi with ABS. i notice today that there's EP90 dripping on the inner of my back brake disc. anyone know what seal is it and the part number please tha will be of great help. thanking you in advance thierry Quote Link to comment Share on other sites More sharing options...
MrKev Posted January 19, 2011 Share Posted January 19, 2011 RTC3511 is the seal that fits inside the back of the hub, and keeps the grease in. If you've got EP90 drippping down the brake disc, there's another seal inside the stub axle that stops the EP90 getting into the hub, where the grease should be. I understand some people omit to fit this to allow the axle oil to provide lubrication to the wheel bearings, but if you've not done this, and you're sure it's EP90 that's on that disc, then I think you might be looking at replacing two seals, plus probably the bearings..? Kev Quote Link to comment Share on other sites More sharing options...
Tibout Posted January 19, 2011 Author Share Posted January 19, 2011 thanks for that. it was a lady owner and i don't think she did that modification. i've just clean my axle breather which was blocked really bad. so going to give the pads and disc a clean and see if it's still leaking. thanks again thierry Quote Link to comment Share on other sites More sharing options...
Tibout Posted January 19, 2011 Author Share Posted January 19, 2011 is RTC3511 seal used for disco 300 as well? was on paddock site and it only mention for defender series i think! i could be wrong some clarification please. Quote Link to comment Share on other sites More sharing options...
