Discovery 1 300tdi Heater Matrix Pipes
fozsug
Trying to find the part numbers for the two pipes , arrowed in the diagram, that go from the heater matrix through the bulkhead . The heater matrix number is STC3135, thought it was the matrix leaking, but it is the pipes....... it a bit cold without the heater so any help would be gratefully recieved :D
Thanks
Tony
STC3917 is the number for the pipes.
it could be the little fiddly seals that seal them into the matrix as the pipes are alloy. best bet is to replace them with some rubber coolant hose and some copper pipe joiners (that's what i'd do next time i have the dash out)
Thanks Al :D
Strewth.... they are nearly as expensive as the matrix....what alloy are they made out of ....must be laced with gold!!
Edited by fozsug
they are aluminium pipes, and are a pain to fit. hence the cut and join method.
where are they leaking from? maybe you could just cut out the middle section and leave the proper ends in place to make life easier
They are leaking from about 1cm up from the heater matrix, looks like someone has had a pair of stilsons on them(not me)and the tubes are cracked :angry:
