will4x4 Posted January 30, 2011 Share Posted January 30, 2011 I asked a while ago about putting a disco arm on a defender so its easier to change the drop arm ball joint. Is there an idiots guide on here with pictures... i just want to check what I'm doing before i go ahead.. Basically i have a discovery 300tdi 1995 steering box with the flat drop arm. I want to bolt that on my 1994 300tdi defender (so get rid of my drop arm that has a bend in it and a ball joint already attached. 1) first question will that work .. will everything turn ok having a flat drop arm ? 2) i was going to use my uprated steering arms that i already have on there and screw in a ball joint to it not sure whats there now thinking about it) 3) lastly buy a steering damper relocation kit and mount the damper differently im sure that's not all correct and could really do with a step by step idiots guide.. does anyone have one please? thank for your help in advance Quote Link to comment Share on other sites More sharing options...
minimaquinas Posted January 30, 2011 Share Posted January 30, 2011 hi i have just swapped mine last week and i found it easier to swap the drop arms as the flat 1 was too close to the other steering bars hope this helps brian Quote Link to comment Share on other sites More sharing options...
