RustyNissanPrairie Posted February 23, 2011 Share Posted February 23, 2011 I'm planning on fitting a 300tdi with a R380 gearbox in the proper 300tdi/R380 factory positions but into a 110 LT77 chassis, are the gearbox crossmembers directly swappable? or do I have to drill/sleeve new mounting bolt holes in the chassis rails? Quote Link to comment Share on other sites More sharing options...
minimaquinas Posted February 23, 2011 Share Posted February 23, 2011 hi i have just done my 110 from a td with lt77 to a 300 with a r380 and the x member needs to be re drilled hope this helps Quote Link to comment Share on other sites More sharing options...
RustyNissanPrairie Posted February 24, 2011 Author Share Posted February 24, 2011 Thanks for the info! can I just pic your brains a bit more? did you put the engine in the proper factory 300Defender position? Does the R380 style crossmember go in the same place as the tube type LT77 crossmember-but just drilled to fit? Thanks in advance Quote Link to comment Share on other sites More sharing options...
