frrfrr Posted July 5, 2006 Share Posted July 5, 2006 hi ive noticed a slight oil leak from the back dif on my 1.8 x reg freelander. does a new dif cover gaskit solve the problem or is there any other things that i should know? thanks Quote Link to comment Share on other sites More sharing options...
Grumpy Posted July 8, 2006 Share Posted July 8, 2006 There isn't a gasket on the rear diff cover it’s just glued on. Take care when removing it as it bends quite easily. I would check the drain plug and breather first though. Quote Link to comment Share on other sites More sharing options...
