PGM316 Posted March 1, 2011 Share Posted March 1, 2011 Do you ever feel that as soon as one problem is fixed, the next appears?! Its started recently, when doing low revs in 3rd and 4th gears (not noticed it in others), theres a low pitched vibration / rattle / rumble. Can't work out exactly where its coming from. I'll probably need to do more investigation to figure out whats causing it? cheers Paul Quote Link to comment Share on other sites More sharing options...
JJB Serenity Posted March 1, 2011 Share Posted March 1, 2011 first thing, check your uj's for play. Also check for play in transfer (does the prop have rotational play?) However, ever since getting my truck I have had a noise that sounds like someone vibrating a sheet of metal when I am in 4th or 5th and doing too low revs while trying to accelerate, particularly when going up a slight incline. I'm just very aware of it now and either accelerate more gently or change down into the correct gear. hope this helps Quote Link to comment Share on other sites More sharing options...
PGM316 Posted March 1, 2011 Author Share Posted March 1, 2011 first thing, check your uj's for play. Also check for play in transfer (does the prop have rotational play?) However, ever since getting my truck I have had a noise that sounds like someone vibrating a sheet of metal when I am in 4th or 5th and doing too low revs while trying to accelerate, particularly when going up a slight incline. I'm just very aware of it now and either accelerate more gently or change down into the correct gear. hope this helps That sounds like a similar problem to mine. Did wonder if it was a lose exhaust bracket, will check the things you mention also thanks. Strange how it started all of a sudden in the last week. Quote Link to comment Share on other sites More sharing options...
JJB Serenity Posted March 1, 2011 Share Posted March 1, 2011 probably a uj then if it started all of a sudden. just speaking from experience though, not through any great expertise so someone else may be able to suggest more things to look at. Quote Link to comment Share on other sites More sharing options...
PGM316 Posted March 1, 2011 Author Share Posted March 1, 2011 probably a uj then if it started all of a sudden. just speaking from experience though, not through any great expertise so someone else may be able to suggest more things to look at. Thanks for the help, it could well be that. Is the UJ something that will just get noisier, or will it suddenly disintegrate? Quote Link to comment Share on other sites More sharing options...
JJB Serenity Posted March 1, 2011 Share Posted March 1, 2011 I think that as soon as they are worn and begin to vibrate it is only a short time before they disintegrate and if they do so while you are driving your prop will fall off! It is for this reason that as soon as I begun to hear a very loud vibration I checked my uj's and attempted (and I mean attempted, I made a right cock-up of it ) to change it when I found play in the joint. Quote Link to comment Share on other sites More sharing options...
PGM316 Posted March 2, 2011 Author Share Posted March 2, 2011 I don't think it's something I'll tackle myself, I'll take it to the garage friday and let them have a go.Cheers JJB! Quote Link to comment Share on other sites More sharing options...
PGM316 Posted March 4, 2011 Author Share Posted March 4, 2011 Turned out to be a prop shaft, luckily not too expensive and back to being a smooth drive again. (Or as smooth as a Defender can be) Quote Link to comment Share on other sites More sharing options...
JJB Serenity Posted March 4, 2011 Share Posted March 4, 2011 The whole prop or just a uj? Quote Link to comment Share on other sites More sharing options...
PGM316 Posted March 4, 2011 Author Share Posted March 4, 2011 The whole prop or just a uj? I think the UJ, the mechanic said it had welded itself up, after a short drive the joint was very hot. Quote Link to comment Share on other sites More sharing options...
