Bobs Posted March 22, 2011 Share Posted March 22, 2011 Hi I've bought an 08 Freelander 2, but it only came with one Key/Remote. I do have a similar remote from a different vehicle but I have been told that once programmed they can't be reprogrammed to a different vehicle. Does anyone know if that is correct and, if not, where I can get it done. Thanks Quote Link to comment Share on other sites More sharing options...
viorelluta Posted March 23, 2011 Share Posted March 23, 2011 If I were you, I would be rather worry about the second original key (the one missing)... where is it, and who could use it to open your car? You should visit a dealer, who should be able to delete that one from your car's memory. The key previously used for some other car should normally work if programmed to your car, as it is basically a RFID chip which, even if stores some info regarding the history (such as "it was/was not programmed"), can also be re-programmed. Both operations need special tools, available at the authorised dealers (hopefully :-) ) Viorel Quote Link to comment Share on other sites More sharing options...
