lansalot Posted April 22, 2011 Share Posted April 22, 2011 Hi folks Per my previous post, I think I'm almost there. I know which terminal is pos and neg on the amplifier. But where do I wire it to? I've seen some wiring it to the alternator and earth, and others to both poles on the coil. When I stuck the multimeter on the coil, I got 10.x and 1.x volts from the two terminals. Doesn't sound pos and neg to me! help! End is in sight, if I get it going tmrw then I'm off to the races on Sunday! A Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted April 22, 2011 Share Posted April 22, 2011 Depending on whether you have a 2-wire or 3-wire connector, it needs to be connected to a 12volt supply, earth (via the body on a 2-wire) and the negative of the coil, which of course it is switching. I guess it can be connected to the coil which is then in turn connected to the ignition switch. Quote Link to comment Share on other sites More sharing options...
lansalot Posted April 27, 2011 Author Share Posted April 27, 2011 Muahahaha etc. Relatively minor work to be done still, but the major hurdle overcome... Quote Link to comment Share on other sites More sharing options...
