Raggie Posted May 24, 2011 Share Posted May 24, 2011 Hello. Advice needed. I have changed both swivel housing and seals on a Disco 1 TDI200 1993. One side is fine but the offside is seeping CV oil. I used the oil that’s with the CV kit. I have been told that this is a common fault on the 200. Also I have been told that there is an additive you can add to the oil to stop this leaking. Or is there something I can do. Rick Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 24, 2011 Share Posted May 24, 2011 You can put the grease in part number STC3435 but if it is leaking oil out, it will leak water in and it will bugger up the CV. Better to fix the leak properly IMO. Quote Link to comment Share on other sites More sharing options...
