mchuk22 Posted May 26, 2011 Share Posted May 26, 2011 accelerator/power Problem I have a 1998/1999 S reg Discovery 1 safari Automatic 2.5 cc Diesel When im driving the land rover i will get to a speed in happy with and take my foot of the accelerator and just put enough pressure on the pedal to keep the disco at the same speed (Cruising) . This is when the engine will loose power and a (check Engine) light will come on. to get the light to go out and get power back all I have to do is press down or release the pedal a bit and every thing is ok. If you have any advice it would be most appreciated Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 26, 2011 Share Posted May 26, 2011 Throttle pedal sensor has been known to cause problems like that, it wears out in the position you normally use and gives an invalid reading but works if you drive boot down! Quote Link to comment Share on other sites More sharing options...
