sargejnr Posted June 16, 2011 Share Posted June 16, 2011 can anyone tell me how to see if my wastegate is stuck, i have no idea where to look or what to look for Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 16, 2011 Share Posted June 16, 2011 On the Turbo - bolted to the alloy side of it by 2 x 10mm head bolts - is the wastegate actuator. A rod comes from it and goes to the arm of the wastegate (which is actually inside the exhaust side of the turbo, and is just a flap). Disconnect the arm from by removing the small clip and pin. You should then be able to easily operate the wastegate by hand. Les. Quote Link to comment Share on other sites More sharing options...
