V8defender90 Posted July 8, 2011 Share Posted July 8, 2011 HI guys, just about to start changing the flange on the rear diff, it is true that i will need a spacer for the new prop??? cheers Matt. Quote Link to comment Share on other sites More sharing options...
sutty_32 Posted July 9, 2011 Share Posted July 9, 2011 You will need a spacer for the flange, but that should come with the flange as its needed for all the 4 bolt flanges. Don't need any kind of spacer for the prop Quote Link to comment Share on other sites More sharing options...
V8defender90 Posted July 13, 2011 Author Share Posted July 13, 2011 Cheers, for your reply. I went ahead with the job and I had purchased the flange which didn't need the spacer. The worst bit was getting the old seal out without scoring the sides. took about an hour and half. would recommend buying a prop shaft nut removal tool, Next on my list. Cheers again. Quote Link to comment Share on other sites More sharing options...
