Frax Posted July 9, 2011 Share Posted July 9, 2011 Hi I need a part No: for the transmission brake shoe retaining springs and cap. The ones that go through the centre of the drum and hold the pad, push on and turn 90 deg. Rav says its STC1532 but I am unable to find that anywhere and most of the time the search just comes back with the pin the holds the brake shoe to the handbrake lever. It for a 1995 300tdi Defender Regards Frax Quote Link to comment Share on other sites More sharing options...
western Posted July 9, 2011 Share Posted July 9, 2011 Diagram & numbers from my microcat attached below. links to each part number STC1526 ICW100050 Quote Link to comment Share on other sites More sharing options...
Frax Posted July 9, 2011 Author Share Posted July 9, 2011 Thank you Ralf yer a star......... Regards Frax Quote Link to comment Share on other sites More sharing options...
western Posted July 9, 2011 Share Posted July 9, 2011 your welcome, you might have noticed the earlier STC numbers has been superseded to the later ICW 9 digit number. Quote Link to comment Share on other sites More sharing options...
Frax Posted July 9, 2011 Author Share Posted July 9, 2011 Yes I did and I did eventualy find the adjuster but the spring part had no pictures so was unsure if it was the correct bit. Are all the part No: changing as I have an old parts download PDF. Regards Frax Quote Link to comment Share on other sites More sharing options...
western Posted July 9, 2011 Share Posted July 9, 2011 LR update their part numbers when a new model or vehicle enters production, so many common parts on 90/110/Defenders have or will change to the 9 digit system, I guess there are a lot more combinations to use. Quote Link to comment Share on other sites More sharing options...
