alternator problems
hi all ive had my alternator on my 90 (disco 200tdi engine) for about 4 months now(recon), last night the egine kept cutting out and re starting then nothing stopped, by passed the kill switch started, battery warning light came on no keys in then once engine running it went out, got the truck home removed the battery put it on charge removed kill switch all together, battery fully charged and re installed went to connect and the earth termminal sparking, removed earth cable removed wires off alternator connected battery then when putting alternator wires back on sparking again and smell of burning.
so is it a battery or alternator problem or is it a earth problem
any helpwould be great please cheers steve.
new alternator fitted still got the same problem
so is it wiring on the back of the alternator (the old td wiring on disco alternator)
or wirirng on ignigtion because when ignition switched on the battery light goes out and oil light comes on as normal
but they both should come on together then go out when engine started correct.
