straightshooter Posted August 12, 2011 Share Posted August 12, 2011 Hi guys need some advice thinking about swapping my 3.5 for a 4.6 would this bolt straight in? if not what mods are required i have a edelbrock carb on the 3.5 and was hoping I could use this for the 4.6 also what engine auxilliries from the 3.5 could I use? any advice wellcome Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 12, 2011 Share Posted August 12, 2011 If the 4.6 is complete with auxillaries then use them, they're all much newer than the 3.5. You *can* swap the 3.5 bits onto the 4.6, the crank nose is longer so you need a spacer if you're putting that front end on. I wouldn't put the edelbrock on, if you do it'll need setting up properly but frankly they're rubbish even when they're right - I'd strongly suggest keeping the EFI bits and megasquirting it. Quote Link to comment Share on other sites More sharing options...
straightshooter Posted August 12, 2011 Author Share Posted August 12, 2011 where do i get a spacer from ? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 12, 2011 Share Posted August 12, 2011 where do i get a spacer from ? RPI sell them, TBH they're not a complicated thing to make in a lathe. It just takes up the extra length and allows the crank bolt to nip up against the pulley. Quote Link to comment Share on other sites More sharing options...
straightshooter Posted August 12, 2011 Author Share Posted August 12, 2011 cool Quote Link to comment Share on other sites More sharing options...
