GBMUD Posted August 25, 2011 Share Posted August 25, 2011 On behalf of Chelsea Tractor who had a recent 'episode'; On a late Td5 Discovery, what is the correct orientation of the UJ yokes on the main part of the shaft? I.E. are the bearing cap holders on the shaft in the same orientation or 90° out? I get the impression that a quick answer is preferred! Cheers Chris Quote Link to comment Share on other sites More sharing options...
GBMUD Posted August 25, 2011 Author Share Posted August 25, 2011 Thanks everyone for the help, don't worry, the rush is off now. Chris Quote Link to comment Share on other sites More sharing options...
nik 1 Posted August 26, 2011 Share Posted August 26, 2011 Thanks everyone for the help, don't worry, the rush is off now. Chris the front is the same hope this helps niksorry mine is a 1999 Quote Link to comment Share on other sites More sharing options...
GBMUD Posted August 27, 2011 Author Share Posted August 27, 2011 the front is the same hope this helps niksorry mine is a 1999 Nik 1, thanks, just the job. As far as I know the prop is getting reassembled. It seems that the front diff input shaft sheared, fell out of the diff and the prop shaft then flailed about and fell apart. Chris Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted August 31, 2011 Share Posted August 31, 2011 The Di/RRC/Defender prop need to "look" out of phase to keep it in phase, it's an unusual instalation. the TD5 prop has one Cardan style joint which is a CV joint, so only the axle end is a non-constant joint. There is no need to align the joints, they should work in any orientation. Quote Link to comment Share on other sites More sharing options...
