Peterla Posted September 7, 2011 Share Posted September 7, 2011 Hi, I have a 300tdi disco that had the rubber donut tail shaft. I have fitted my old 200tdi rear ARB diff lock but was unable to use the 200tdi tail shaft as it was damaged when I rolled the car four times. I have purchased a range rover tail shaft which has the uni joints and a slide collar. My concern is the slide collar is a fair way out and I am not sure what is normal on these. Does anyone know what the normal distance on this tail shaft slide should be as I am concerned that the gear might not be deep enough and strip. Any help on this would be greatly appreciated before I get stuck with a stripped tail shaft. Many thanks Peter Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted September 11, 2011 Share Posted September 11, 2011 Nominally hey are the same. If the splines are hanging out then it's too long. As a guide the rubber collar pops off if they over-extend. Quote Link to comment Share on other sites More sharing options...
Peterla Posted September 12, 2011 Author Share Posted September 12, 2011 Thanks for the reply. The Rubber pops off about 10mm from the length when fitted. Way to short so I have purchased a 200tdi disco one and it is the perfect lenght. Not happy at the agent that told me the rangerover one will be fine. Pete Quote Link to comment Share on other sites More sharing options...
