NicTheOrange90 Posted August 2, 2006 Share Posted August 2, 2006 Fixed the deraded spring (30 seconds to swap spring - 2 hours to strip door, remove lock, and reassemble) .. door now opens from outside without having to reach in from rear door to pull up lock jobby However with door trim and handles and stuff attached, the door wont open from inside or outside - had to slim jim it Take trim off and all works fine ... Any sugggestions? Quote Link to comment Share on other sites More sharing options...
NicTheOrange90 Posted August 5, 2006 Author Share Posted August 5, 2006 Adjusted the external handle rod (it has a screw adjustment) Put the door trim on a bit at a time, and it now opens from inside and outside ! Quote Link to comment Share on other sites More sharing options...
