yildiz Posted October 9, 2011 Share Posted October 9, 2011 Guys had the classic pivot through the clutch lever, so took engine out replaced clutch with Borg & Beck, replaced lever, slave cylinder, master cylinder and thrust bearing, bleed system no air took car out after few miles gear selection getting hard, got back home took look at master cylinder no fluid loss rebleed no air took it out again but after few miles gear selection hard again, took engine out again nothing there wrong all looks fine back in again but still the same problem, any ideas guys Quote Link to comment Share on other sites More sharing options...
fozsug Posted October 10, 2011 Share Posted October 10, 2011 Had the same, cured by using a pressure bleeder Quote Link to comment Share on other sites More sharing options...
dantd5 Posted November 8, 2011 Share Posted November 8, 2011 When you put the transfer gear stick back, was it alligned? Just did mine with Valeo and clutch never engaged until I found out that they never aligned when I screwed them back... Also be sure the brake fluid is going perfectly through. Tried finding a pic to get my point but could not find it!!! sure here it is,,,,, Quote Link to comment Share on other sites More sharing options...
