piranha Posted December 18, 2011 Share Posted December 18, 2011 hi, I'm new to this forum. I'm having an issue with my 1991 discovery 200tdi. i get a scrapping noise in all gears except 4th (even reverse) it goes away when the clutch is pressed or if coasting in neutral. The car has a brand new prop shaft on the front, (the noise was present before the prop change). gear change is smooth with no grinding. any ideas? any help would be very welcome. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted December 19, 2011 Share Posted December 19, 2011 Probably the clutch thrust bearing. What you describe is a typical symptom of that. Les. Quote Link to comment Share on other sites More sharing options...
piranha Posted December 19, 2011 Author Share Posted December 19, 2011 Thanks, I'll check it out. Quote Link to comment Share on other sites More sharing options...
yildiz Posted December 19, 2011 Share Posted December 19, 2011 Spot on Thrust bearing Quote Link to comment Share on other sites More sharing options...
