strong32 Posted January 17, 2012 Share Posted January 17, 2012 hi dont seem to be able to open the rear door on my disco tdi, it is unlocked on the fob ,the locking thingy goes up and down on the fob and when the key is used, but the door will not open when you lift the handle. any ideas please, thanks in antisippation. strongie Quote Link to comment Share on other sites More sharing options...
Thys Posted January 18, 2012 Share Posted January 18, 2012 On mine I had the same, I could open the door from inside only. I removed the rear door panel, and found a leaver that worked loose, linking the external handle to the release mechanism. Being in the bush, I simply put a cable tie through the two corresponding mounting holes to keep the lever in its moving arch, and it worked. As a matter of fact, I did the field repair in March 2008, and it is still holding up. The arch movement is very little, so the cable tie is not subjected to a lot of friction..... Quote Link to comment Share on other sites More sharing options...
peterdon Posted January 18, 2012 Share Posted January 18, 2012 Prise the "Land Rover" badge off and spray some lubricant/WD40 in, it may free it up. Quote Link to comment Share on other sites More sharing options...
Igol Posted January 20, 2012 Share Posted January 20, 2012 And in the meantime get a new spring bought as it wont belong before it snaps and you need to replace it. Quote Link to comment Share on other sites More sharing options...
