mudmagnet Posted March 10, 2012 Share Posted March 10, 2012 in the three years i have had my disco the rear windows havent worked, i have swapped the switches over to check them and all fine, so i removed the window ecu and sure enough there was a dry solder joint, so i re soldered this joint, put it all back together and still they dont work, what a waste of 2 hours. Quote Link to comment Share on other sites More sharing options...
godzilla84 Posted March 11, 2012 Share Posted March 11, 2012 Have you tried spraying silicone spray on the window runners/mechanism? Mine were siezed solid at the back through lack of use. Quote Link to comment Share on other sites More sharing options...
fozsug Posted March 11, 2012 Share Posted March 11, 2012 Take a door panel off and check you have power to the motor Quote Link to comment Share on other sites More sharing options...
