Fuel pipe leak by sedimentor
DrRob
'93 200Tdi Classic:
Got a small leak from the metal piping/union exit from the sedimentor bowl (i.e.engine side)...what and where can I use to fix it? It's the orginal short metal section with the union to the sedimentor.....would rather a solution that doesn't involve replacing the whole pipe....
I was thinking to cut the plastic pipe and attach a short lenth of tubing with a suitable union.............?
Any help much appreciated......
Cheer! Found that earlier. Need to check if ESR2994 (300Tdi) will be OK for 200Tdi - bends wise not fittings. Existing one has some specific snakelike bending patterns near sedimentor....will call Britcar...
Folks, what size are the pipe end fittings for the pipe in question i.e. sedimentor outlet and fuel pump inlet......I assume they are a BSP of some description....? Thanks in advance Rob....
