SharkyMarc Posted May 7, 2012 Share Posted May 7, 2012 Evening all, I recently came back from a pay and play site wi two clicky CV's and a possible wheel bearing problem. Both m swivels are quite pitted as well. Would I replace whole axle or rebuild what I have? Quote Link to comment Share on other sites More sharing options...
Niamh Posted May 7, 2012 Share Posted May 7, 2012 Personally I'd rebuild replacing what's necessary. Niamh Quote Link to comment Share on other sites More sharing options...
team-anarchy Posted May 7, 2012 Share Posted May 7, 2012 Weigh up the cost, and what you Wana run the motor for, I'm sellin td5 front with arb locker and hardened crown wheel and pinion 4.76 gear hardened flange, and same for rear but also with ashcroft hardened shafts in rear, £600 front, £700 rear, or £1200 pair,? Let me know if your interested Quote Link to comment Share on other sites More sharing options...
stuck Posted May 7, 2012 Share Posted May 7, 2012 +1 for rebuilding. At least you will know what you have then. (No disrespect to Team-Anarchy intended!) Quote Link to comment Share on other sites More sharing options...
minimaquinas Posted May 7, 2012 Share Posted May 7, 2012 hi i think it would be better to rebuild as the axle you buy may be on its way out and then your back to square 1 hth brian Quote Link to comment Share on other sites More sharing options...
team-anarchy Posted May 7, 2012 Share Posted May 7, 2012 None taken stuck, just offering a cheap GD replacement for quality parts, but as ya say, unless ya know the truck, ya never know Quote Link to comment Share on other sites More sharing options...
stuck Posted May 7, 2012 Share Posted May 7, 2012 If both your axles have lockers fitted then that is a good price... I'd have them in a shot but lockers aren't allowed in the class I run in Quote Link to comment Share on other sites More sharing options...
team-anarchy Posted May 7, 2012 Share Posted May 7, 2012 Yes both my axles have lockers, arb'd are switched on and off, so what ever class your in, ya can just disconnect the switch to stay in your class, that way it's just the same as having a 4 pin diff Quote Link to comment Share on other sites More sharing options...
SharkyMarc Posted May 7, 2012 Author Share Posted May 7, 2012 How recently have bearings etc been done? Ideally I think a standard replacement may be more in my price range as its only a weekend toy rather than a challenge truck but something to think about. Would def td5 fit straight onto disco 1? Quote Link to comment Share on other sites More sharing options...
team-anarchy Posted May 7, 2012 Share Posted May 7, 2012 the axles were built 1 challenge ago, and about 4 pay and play days ago. and no more than 300 miles ago. rear axle needs brake pads, other than that there ready to rock. i fitted these axles to my g registration defender 90. so yes they should fit straight on to a disco 1. the axles are off an 02 td5 90. Quote Link to comment Share on other sites More sharing options...
SharkyMarc Posted May 7, 2012 Author Share Posted May 7, 2012 What ancillaries would they come with? Anything in the way of radius arms etc? Are you on portals now then? Quote Link to comment Share on other sites More sharing options...
team-anarchy Posted May 7, 2012 Share Posted May 7, 2012 If ya wanted the standard td5 radius arms £25 If ya want the tracking bar fitted with a dan bar sleeve £40 And if you wanted the heavy duty tracking guard, £50 I'm not releasing my giggle pin trialling arms, as I'm using them, mog axles not fitted yet, I only removed my arb axles this weekend, (Saturday) Quote Link to comment Share on other sites More sharing options...
