minimaquinas Posted May 25, 2012 Share Posted May 25, 2012 hi guys is it a easy job to convert a 1978 series 3 light weight to a 300 tdi ie will the tdi mount up to the series gearbox if not what is needed thanks in advance brian Quote Link to comment Share on other sites More sharing options...
ejparrott Posted May 26, 2012 Share Posted May 26, 2012 300's have been fitted onto Series gearboxes so I don't see why not. They are also fitted into normal Series' so a lightweight shouldn't pose any major difficulties. Will you be converting to PAS though? Its not needed on a shorty, but you do need to do something about the PAS pump, and I don't know if its as easy with a 300 as it is with a 200. Quote Link to comment Share on other sites More sharing options...
tuko Posted May 26, 2012 Share Posted May 26, 2012 The PAS pump was easy to solve when I ran without PAS. I ran the two lines from the pump to the reservoir which allowed them to circulate the PAS fluid back and forth. OH, BTW Brian the PAS pump works like a charm! Super happy, thanks mate. Todd. Quote Link to comment Share on other sites More sharing options...
minimaquinas Posted May 26, 2012 Author Share Posted May 26, 2012 hi todd im glad your happy with it i am thinking of buying a light weight and converting it and so far it looks like it is do able but knowing my luck i will hit a major problem but if it goes ok it will be a nice toy Quote Link to comment Share on other sites More sharing options...
