white90 Posted August 7, 2005 Share Posted August 7, 2005 If you lift the suspension of your 90-300TDI or TD5 and fit castor correction arms to the 300TDI you may well adopt a vibration on overrun around 60MPH+ the pics below show the prop angles with a wide yoke prop fitted note the acute rear UJ angle and the front UJ running flat. I fitted a Disco2 Double carden prop this sorted the problem, you'll need the Disco 2 transfer box flange to fit the prop BTW See also:http://forums.lr4x4.com/index.php?showtopic=14261&hl= Link to comment Share on other sites More sharing options...
