Marten Posted June 12, 2012 Share Posted June 12, 2012 Have acquired a wired engine oil pressure gauge with sender. Plan to fit the sender in place of the fitted oil pressure switch. The sender body is larger than the switch and fouls the oil cooler pipe fittings. I need a short connector to move the sender unit out from the filter block. The existing switch and the sender unit are both threaded 3/8 - 24 NF. I have 3/8 - 24 UNF brake pipe fittings, 1 x male/male connector and 1 x female/female connector, that fitted together would do the job, but the threads don't match. Has anyone come across a source of 3/8 - 24 NF pipe connectors? I'm all Googled out! Quote Link to comment Share on other sites More sharing options...
western Posted June 12, 2012 Share Posted June 12, 2012 I used TD engine parts on my 20tdi to fit the oil temp & pressure gauges in my 110. http://smg.photobucket.com/albums/v384/western214h/oil%20pressure%20and%20temperature%20transmitter%20locations/ Quote Link to comment Share on other sites More sharing options...
Marten Posted June 13, 2012 Author Share Posted June 13, 2012 That looks to be just the job! Many thanks! Quote Link to comment Share on other sites More sharing options...
