Brett Posted August 29, 2006 Share Posted August 29, 2006 Does anyone know the part numbers for all four front hinges for a 90? PLEASE NOTE! These must be the latest type of hinge, as fitted to Td5's that have the small washer or bushing between the two parts of the hinge. Thankyou. Quote Link to comment Share on other sites More sharing options...
Matt Neale Posted August 29, 2006 Share Posted August 29, 2006 Does anyone know the part numbers for all four front hinges for a 90?PLEASE NOTE! These must be the latest type of hinge, as fitted to Td5's that have the small washer or bushing between the two parts of the hinge. Thankyou. Not sure if this is what you want: From VIN 1A602284 BDB710160 Hinge assy door - front door upper - self colour - RH BDB710170 Hinge assy door - front door lower - self colour - LH Matt Quote Link to comment Share on other sites More sharing options...
Brett Posted August 30, 2006 Author Share Posted August 30, 2006 Not sure if this is what you want:From VIN 1A602284 BDB710160 Hinge assy door - front door upper - self colour - RH BDB710170 Hinge assy door - front door lower - self colour - LH Matt Hi Matt. thanks for taking time to check. Not sure if they are, the correct ones, think they might be though as the standard hinges begin MCX. You haven't got the numbers for front upper LH & Front lower RH as well have you? Thanks Brett Quote Link to comment Share on other sites More sharing options...
Matt Neale Posted August 30, 2006 Share Posted August 30, 2006 You haven't got the numbers for front upper LH & Front lower RH as well have you?Thanks Brett D'oh! I've got the other part numbers at home - I'll look them up later for you. Could have sworn I typed them all in last night, but obviously not!!! Catch you later, Matt Quote Link to comment Share on other sites More sharing options...
Matt Neale Posted August 30, 2006 Share Posted August 30, 2006 Hi Matt. thanks for taking time to check.Not sure if they are, the correct ones, think they might be though as the standard hinges begin MCX. You haven't got the numbers for front upper LH & Front lower RH as well have you? Thanks Brett As promised:- From VIN 1A602284 BDB710160 Hinge assy door - front door upper - self colour - RH BDB710170 Hinge assy door - front door upper - self colour - LH BDB710180 lower - self colour - RH BDB710190 lower - self colour - LH Matt Quote Link to comment Share on other sites More sharing options...
Brett Posted August 31, 2006 Author Share Posted August 31, 2006 As promised:-From VIN 1A602284 BDB710160 Hinge assy door - front door upper - self colour - RH BDB710170 Hinge assy door - front door upper - self colour - LH BDB710180 lower - self colour - RH BDB710190 lower - self colour - LH Matt Cool B) Thanks for the effort Matt Quote Link to comment Share on other sites More sharing options...
