stuck Posted July 30, 2012 Share Posted July 30, 2012 Gent's, After a lot of swearing I've managed to get the half shafts out of of my S1's back axle (I take it a field repair was not an option on these things!) I don't have a press so once I've changed the bearings and seals am I going to be able to reassemble them? It took two 30 Te hydraulic jacks to get the shafts out! Cheers, Mick. Quote Link to comment Share on other sites More sharing options...
steve b Posted July 31, 2012 Share Posted July 31, 2012 Did you cut the bearing retaining ring off the halfshaft or heat it up to remove it first ? As that is what keeps everything on the axle its a kin tight fit as you have found. The bearing itself is a press fit iirc between 5 &10 tons and the retainer is much tighter cheers Steveb Quote Link to comment Share on other sites More sharing options...
stuck Posted July 31, 2012 Author Share Posted July 31, 2012 Steve, Rightly or wrongly i left a couple of bolts securing the bearing housings to the axle tubes and jacked the half shafts out of the bearing, oil seal & retainer (bearings were knackered any way). I don't appear to have bent the drive flanges but it was always a possibility... Quote Link to comment Share on other sites More sharing options...
