Bigant Posted August 26, 2012 Share Posted August 26, 2012 I am replacing the front disc's on the wife's Disco and the Haynes manual indicates that it should be possible to slide the calipers off the discussion once the brake hose top clamp on the swivel housing has been undone? However as far as I can see this is not possible as the whole mudshield is connected to the top clamp. Is there a way of getting the caliper out of the way without undoing the brake pipe and losing all the fluid? Cheers Bigant Quote Link to comment Share on other sites More sharing options...
dirtyninety Posted August 26, 2012 Share Posted August 26, 2012 Yes, remove the mudshield retaining bolts, then remove the hose top clamp from the swivel pin bolts. You should be able to just push the caliper out of the way to remove the disc. Quote Link to comment Share on other sites More sharing options...
