Discovery td5 rear axle leak
Hamish Grundy
Hi, i have done a search and could only find leaks from the o ring on the back of the hub, mine is leaking down the splines of the shaft, i found that the nut on the half shaft was loose but it does still leak, what should seal this? i was thinking of putting an oring behind the nut. have i got something missing?
thanks alot.
Hamish
