quedge Posted December 16, 2012 Author Share Posted December 16, 2012 and that's the weakness of the high pinion 79/80/100 series front CWP, as a lot of LC drivers find out here. A GQ/GU Patrol ffront diff is miles stronger than either Rover or LC, (it's a Sals/D60 size high pinion CWP, and you lose a bucket load of ground clearance as a consequence) but from what the Rover boys that have fitted them reckon, the CV stubs aren't much better than Rover,so it ends up being swings and merry-go-rounds. At least the GQ/GU front end is an easier fit than the LC front. only think that puts me of the nissan front axle is the cost of an arb locker. as im after front and rear locking diffs what about matching diff ratios? Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted December 16, 2012 Share Posted December 16, 2012 The toyota front diff is only weak compared to the rear diff, it is still way stronger than a rover diff. I ran a 80 series axles front and rear with 37 boggers and never blew a diff, i did blow a few cv's though. Longfield http://www.longfield...?category=FJ-80 do cv's and front shafts for the 80 series axles, lifetime warrenty as well. I enquired whether the warrenty would cover me on 37's, they have no tyre size restiction on thier warrenty and were quite amused that i thought i could break them with only 37's and a small diesel engine !!! On the diff ratios between the toyota and nissan, both companys most common ratios are 4.11:1 so they are quite easy to match. Quote Link to comment Share on other sites More sharing options...
muddy Posted December 16, 2012 Share Posted December 16, 2012 Did you manage to break the longfeilds Dan? Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted December 16, 2012 Share Posted December 16, 2012 I didn't order, i was at the balence point with the truck. i sold it before i got in too deep. But i researched them in some depth and the only people i could find that had broken them were running 40's on slick rock with welded diffs. Quote Link to comment Share on other sites More sharing options...
quedge Posted December 25, 2012 Author Share Posted December 25, 2012 What do you guys do when matching landrover props with Toyota diffs Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted December 25, 2012 Share Posted December 25, 2012 What do you guys do when matching landrover props with Toyota diffs Machine the toyota flanges to land rover pattern. Diff noses are a very similar length to you shouldn't need to alter the prop lengths. Quote Link to comment Share on other sites More sharing options...
