90200tdi Posted November 28, 2012 Share Posted November 28, 2012 Hi, Quick question 1982 RRC when the lights are turned on the flasher-horn-dip switch will not turn on the Main beams, it just stays on Dip beams. It will only put on the Main beams if you pull back on the stalk, like to flash the lights. So main beams work. Is there a relay hiding somewhere in the bowels of the dash for the main beams, or is the flasher-horn-dip switch fubar ? Quote Link to comment Share on other sites More sharing options...
