matto-disco-1 Posted December 31, 2012 Share Posted December 31, 2012 hiya guys could somebody help me please i went to do my rear discs on my discovery 1 300 tdi and removed the hub assembly then removed the 5 disc securing bolts , but the disc would not come free from the hub am i doing somthing wrong or is it just seised? many thanks matt Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted January 1, 2013 Share Posted January 1, 2013 It will be seized. Do you need to reuse the disc? If not then then go all round it hitting with a big hammer while supported on a bench by the brake disk, making sure the hub is not suppored. Eventually the hub will drop out under its own weight. Don't be tempted to hit the hub to drift it out. Quote Link to comment Share on other sites More sharing options...
Tanuki Posted January 1, 2013 Share Posted January 1, 2013 As Orgasmic Farmer says, it's just seized/corroded on. Usually it will come off if you give it a good twatting with a lump-hammer (my approach is to take the hub and bolt it back on to the wheel with a couple of the wheelnuts: then repeatedly hit the outer part of the exposed face of the disc all the way round - you're trying to rock the disc on the hub-spigot). Heat can help - though I once had to split the disc by cutting two slots in the thing with an angle-grinder and then driving steel wedges in to fracture it. Make sure you clean up the hub-face before you fit the new disc: if the disc doesn't seat perfectly cleanly on the machined face of the hub, it will stress when you tighten the bolts and this can cause brake-judder. Quote Link to comment Share on other sites More sharing options...
matto-disco-1 Posted January 1, 2013 Author Share Posted January 1, 2013 hiya guys chers for the replys i have alread tried wacking it and it did not free i even tried a chizzle between the hub and disc and it still wouldent come free ? but i will try your method and see if i have any luck many thanks matt Quote Link to comment Share on other sites More sharing options...
matto-disco-1 Posted January 1, 2013 Author Share Posted January 1, 2013 chers guys i have tried wacking it but i will try yor method and see if i get any luck many thanks matt Quote Link to comment Share on other sites More sharing options...
