Disco 1 indicator problem
JimDay
My Disco 1 has a problem withe the self cancelling mechanisim as in it doesn't self cancel. I have removed the steering wheel & the column shroud & the black pastic ring that cancels the indicator arm is intact & works fine with the wheel off, but when reasembled the ring seems to low away from the wheel so the 2 lugs on the ring don't engaged with the back of the wheel I thought of moving the column down at the joint under the bonnet but the wheel is already nearly touching the column shroud anyone any ideas please, as to a cure
JimDay
