Japstick Posted April 2, 2013 Share Posted April 2, 2013 Did a compression test on my 3.5 V8 as its drinking water and oil. 136k miles. Test was done with engine warm, all plugs out. I done each test 3 times and took the average. Results:Cylinder Dry Wet1 140 1392 138 1523 140 1504 145 1535 138 1456 150 1627 150 1538 142 153What should the compression be for this engine? Looking at these I don't see any reason for head gasket blown - can a fault not show up on a compression test? I was assuming I was going to have to do an engine rebuild this summer but now not sure it's needed? Quote Link to comment Share on other sites More sharing options...
qwakers Posted April 2, 2013 Share Posted April 2, 2013 its looking ok to me, its showing some signs of ring wear but nothing terrible... Quote Link to comment Share on other sites More sharing options...
Japstick Posted April 4, 2013 Author Share Posted April 4, 2013 thanks qwakers. Any ideas about losing water? Quote Link to comment Share on other sites More sharing options...
qwakers Posted April 4, 2013 Share Posted April 4, 2013 could still be headgasket. could also be the waterpump, crack in block (hope not lol) radiator,heater matrix, hose, etc etc. as for the oil use, the list is as long as your arm on that one. if your worried about a failed headgasket i'd suggest getting a sniff test done, give you a answer either way. Quote Link to comment Share on other sites More sharing options...
idioms Posted April 6, 2013 Share Posted April 6, 2013 hy there what do the plugs look like ,the answer could be there,when you first removed them. Quote Link to comment Share on other sites More sharing options...
Japstick Posted April 6, 2013 Author Share Posted April 6, 2013 Plugs looked ok. Nice chocolate colour. I took the car down my MOT station today and got them to put their emissions probe in the expansion tank to look for exhaust gases. There was no reading at all. So I think I have a coolant leak rather than head gasket issue. Quote Link to comment Share on other sites More sharing options...
idioms Posted April 8, 2013 Share Posted April 8, 2013 pressure test water system maybe the next step ,how much water and oil does it use? Quote Link to comment Share on other sites More sharing options...
