Steering adjustment - how much
I am starting to get more into RTV's and would like to get a better turning circle.
My 90 has 265 tyres on wolf rims, the steering stops are screwed in tight and I have no issue with rubbing on radius arms. But that got me thinking...
I was wondering if I went to 235 or 7.50 tyres how much tighter could I turn if I changed the steering stop bolts to something that would allow me to screw them in more as the bolts have that stepped shoulder.
If I had loads more turning circle would that damage the CV joints?
Cheers
Ian
You could get some offset rims, though it does put more strain on the bearings.
I have 265 kuhmo mud terrains with offset rims and the steering stops are set at 45mm with no rubbing...
Cheers,
Mike
http://landrover.workshop-manuals.com/defender300tdi/index.php?id=382
Have a look at the link above... the only reason i've adjusted it is because I've got some new rims and the bloke in ATS nearly ripped the tyre off on full lock!
You can get modulars rims with an offset of 35ish mm...
cheers, Mike
