duncmc Posted June 8, 2013 Share Posted June 8, 2013 Anyone got any ideas please to help me solve a problem. When I pull the handbrake on I should have 2 warning bulbs light up on the dash. Recently I only get 1 which is the auto transmission fluid light. The other which doesn't come on is the handbrake warning/brake fluid level lamp. I know the bulb itself works because it lights up when I turn the ignition on as part of the ABS check warning lights. And I know the micro switch on the handbrake is working because the transmission light comes on as I pull the handbrake on. I have had a look at the wire on the handbrake switch which looks OK, but I don't know what to check next. I am puzzled. Anyone got any ideas please? Its a 1993 RRC auto with ABS. Thanks Quote Link to comment Share on other sites More sharing options...
duncmc Posted June 16, 2013 Author Share Posted June 16, 2013 Eventually I managed to fix this fault. Last weekend I actually took the micro-switch off the handbrake lever to check it. And of course it was fine. After more searching on Google, I found no answer to the problem, but mention of connections from this circuit to the brake level circuit. So today I cleaned the contacts on the brake level sensor (which had got contaminated with brake fluid at some point). I used contact cleaner, and hey presto - 2 working lights when the handbrake is on. Sorted! Quote Link to comment Share on other sites More sharing options...
