reb78 Posted July 23, 2013 Share Posted July 23, 2013 As above. Along with the leaky core plug, I had a leaky PAS pump. I've bought a new pump, but there is obvious wear on the drive for the water pump on the back of the old pump. This wear is mirrored where the PAS drive keys into the water pump drive. Question is, is there any need to change the water pump at the same time as the PAS pump now?? Pics: Old PAS pump water pump drive New PAS pump water pump drive Water pump drive (wear is circled on the bottom left - you cant see the wear on the top right circle, but it is the same) Sorry the last image isn't the clearest, but I hope you get what I mean. So....what do you reckon?? I guess it should be ok, but what would you do? Do I need to replace the damn water pump too? Quote Link to comment Share on other sites More sharing options...
