Dorsetfreelander Posted August 17, 2013 Share Posted August 17, 2013 Had a scare recently when the red oil pressure light came on whilst driving (it looks like an oil can). There was plenty of oil in and sounded OK but light remained on after stopping and starting the car etc so took it to my local garage who had done some work on it that day. They found that the wire to the sensor just needed "waggling" a little and the light went out so presumably the connector had been disturbed. The sensor is not visible from the top of the engine but it is located just under the front near the middle and there is a blue wire that goes there which you can follow with your fingers. Hope this helps someone. Quote Link to comment Share on other sites More sharing options...
