Paul1967 Posted August 26, 2013 Share Posted August 26, 2013 Hi I'm new to this site but I have had a few landrovers but could do with some advice please. My 1997 disco 1 is crunching into fourth gear and won't go into reverse it was like this when I bought it and was told it was fine prior to new clutch being fitted. I have had the gearbox out to check clutch was fitted correctly and found no fault with clutch. Apart from it being a britpart clutch found nothing apart from weeping slave do you think the gearbox needs changing Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 26, 2013 Share Posted August 26, 2013 Change the weeping slave first, it could give you symptoms as you describe. Quote Link to comment Share on other sites More sharing options...
