gadget Posted October 21, 2013 Share Posted October 21, 2013 Folks, I'm in the process of replacing my rear brake pipe and rear hoses, and whilst everything is off i thought i'd replace the front chassis flexis too. Lower pipe connects are easy enough but how are you supposed to tighten up the upper nut on the nearside chassis flexi? The offside is tight for access but the nearside is silly. (For clarity i'm refering to the flexis that connect the ABS block downpipes to the chassis pipes.) Quote Link to comment Share on other sites More sharing options...
gadget Posted October 26, 2013 Author Share Posted October 26, 2013 You have to remove the offside upper before you can access the nearside upper properly. An absolutely stupid place to put the connectors. Quote Link to comment Share on other sites More sharing options...
