dasterdly Posted October 8, 2006 Share Posted October 8, 2006 evening, just wondering if you could go outside and measure the vent panel depth B) Quote Link to comment Share on other sites More sharing options...
Steve_M Posted October 8, 2006 Share Posted October 8, 2006 evening,just wondering if you could go outside and measure the vent panel depth B) Taking measurements from mine I get the following: At the base of the panel there is a vertical section of 10mm depth, it then becomes sloped and this section extends a further 135mm (with the tape measure parallel to the panel). Hope this helps Steve Quote Link to comment Share on other sites More sharing options...
dasterdly Posted October 8, 2006 Author Share Posted October 8, 2006 Taking measurements from mine I get the following:At the base of the panel there is a vertical section of 10mm depth, it then becomes sloped and this section extends a further 135mm (with the tape measure parallel to the panel). Hope this helps Steve evening, looks like i am missing a good 10 mm from my vent panel ! i have looked at hundreds of airportable pics, but most are all botled together, so its not easy to gauge profiles etc, an ideal situation would be a complete picture of just a vent panel from various angles. thank you for taking the time to measure your vent panel for me, i can at least now get started on making a new one. cheers... Quote Link to comment Share on other sites More sharing options...
