muttleyd Posted November 2, 2013 Share Posted November 2, 2013 Well this weekends job was to start fitting the hardware for the soft top. Where do you position the clamp rail. Looks like it should be sat forward, but then the clamps would be in the thick part of the header and looks like they would not fit. Sat back it doesn't look right. The instructions don't show it. Like a bit of guidance please before I drill some oles... Quote Link to comment Share on other sites More sharing options...
Boris113 Posted November 2, 2013 Share Posted November 2, 2013 This is an old picture I found of mine if it helps. Unfortunately I'm out of the country but can always ask my brother to get some more pics if required. It appears to be mounted in the same place as your first picture. I have a feeling there were either a couple of holes drilled in the surround, or some dimples that seemed to line up with the holes in the top rail so I went with them. Never had any problems with mine as it is. Harry Quote Link to comment Share on other sites More sharing options...
muttleyd Posted November 3, 2013 Author Share Posted November 3, 2013 Cheers Harry. Drilled the holes, obvious in the end when I measured all the bits up and looked at your pics Mark Quote Link to comment Share on other sites More sharing options...
