orangebox Posted November 15, 2013 Share Posted November 15, 2013 Hello, I have a pre-Defender 90 and it's been sat idle for a couple of months since its MOT. I started it up today, and none of the rear lights are working. No running reds, no brake lights, no fog light, and no RHS indicator. The left rear indicator does work. I've connected a trailer light bar and the same things happens on there - only the left indicator works. All of the front lights and dashboard lights work as they should. Can anyone recommend anything to look at/clean/check in particular? Many thanks. Quote Link to comment Share on other sites More sharing options...
ballcock Posted November 15, 2013 Share Posted November 15, 2013 Sounds like an earth fault try a jump lead from the battery to the earth block at the rear corner. Quote Link to comment Share on other sites More sharing options...
bluehaze Posted November 15, 2013 Share Posted November 15, 2013 Check the rear earth. Was everything ok before you fitted the trailer lights? Quote Link to comment Share on other sites More sharing options...
