mattD110td5x Posted September 8, 2005 Share Posted September 8, 2005 Hi All, I've just noticed that the rocker cover gasget is seeping at the firewall end, I guess this is the result of me replacing the injector harness in a misguided attempt to stop the oil escaping through the ECU. Is there any recommended gasget sealer or any knack to sealing around the semicircular piece at the firewall end? thanks guys, Matthew Quote Link to comment Share on other sites More sharing options...
110CSWDEFENDER Posted September 8, 2005 Share Posted September 8, 2005 Hi Matt. It might be worth taking a look at your crankcase ventilation system to make sure that the crankase isn't being pressurised, which will tend to make engine oil leakage worse. Don Quote Link to comment Share on other sites More sharing options...
John_T Posted September 9, 2005 Share Posted September 9, 2005 Like you I changed my injector loom (problem solved BTW!) and had a bit of fun fitting the new gasket (you did use a new one didn't you?). Basically the trick is to get the little "half moon" bit of the gasket seated properly in its place. I managed this without sealant but it it plays hard to get a bit of Blue Hylomar just to hold it where it needs to be would be OK. Quote Link to comment Share on other sites More sharing options...
imspanners Posted September 9, 2005 Share Posted September 9, 2005 It is also recommended to place some RTV (black sealant) in the very corners where the half-moon meets the flat, on the head. This will seal any distortion of the seal at the corners! Quote Link to comment Share on other sites More sharing options...
MartinL Posted September 11, 2005 Share Posted September 11, 2005 Just thought I'd add to this and say that I agree that it is highly likely to be the rocker cover gasket not fitted correctly. I think there is/was a Land Rover service bulletin about it. Quote Link to comment Share on other sites More sharing options...
