problem with driver window
fireone27
Most likely to be a worn plastic gear in the motor assembly, they wear with age and replacements are readily available new and S/H, if buying S/H you need to see it in person to check for wear not just the cheapest on ebay as you just waste money that way. Might go against your grain but genuine parts will give you the best service life as they did last ten years! Expect half that life span from aftermarket parts.
