fireone27 Posted January 25, 2014 Share Posted January 25, 2014 help please my driver window on disco 2 2004 makes a toc toc toc noise when we bring the window up , and now it has droped about 2mmm its stays partly opened can anyone tell me what the cause can be ... and how to fix it ..... thanks for the help . Quote Link to comment Share on other sites More sharing options...
Nigelw Posted January 26, 2014 Share Posted January 26, 2014 Most likely to be a worn plastic gear in the motor assembly, they wear with age and replacements are readily available new and S/H, if buying S/H you need to see it in person to check for wear not just the cheapest on ebay as you just waste money that way. Might go against your grain but genuine parts will give you the best service life as they did last ten years! Expect half that life span from aftermarket parts. Quote Link to comment Share on other sites More sharing options...
