stuckinthemud Posted January 31, 2014 Share Posted January 31, 2014 I've recently had the head gasket done on my TD5 D2 and now suffering low power.As part of the head work, the injectors were sent for cleaning and checking, quoted as being 70-80% efficient.The timing has been checked after the head work and confirmed correct, as were the injector positions when they were replaced (so the codes match the ECU).What I'm being told is that cleaning the injectors can sometimes cause a drop in performance.Is this the likely problem, or do I need to look elsewhere? Quote Link to comment Share on other sites More sharing options...
