Front Prop
The rear prop is held firm by the handbrake, the front however isn;t, the centre diff allows it to turn in relation to the rear, and the front cv joints, splines on shafts, and play in front diff will all add up to quite a bit of rotational play in the prop, ignore it, unless the play is in the uj's on the shaft!
Thanks The UJs are OK.
